How to attach battery
I have bought a new replacement battery from iFixit two months ago and I’ve replaced it. Unfortunately with the heat the adhesive is gone and I have a battery that is moving inside my MBP 13. Is there a way to solve this? I’m noticing that the battery drain quickly, now it’s at 87.9% of total, but it have only two monts of life and 100 loadcycle. Can. i fix this issue?
UPDATE
As requested this is a screen from CoconutBattery. Before the problem I had an 87.9% now as I wrote in a comment, the battery isn’t recognized anymore. Already tried to reset the SMC!
Questa è una buona domanda?
2 Commenti
First lets get a better idea on whats happening with your battery. Install this gem of an App CoconutBattery With the MagSafe charger plugged in take a snapshot of the apps main window and post it here so we can see Aggiungere immagini ad una domanda
da Dan
I Use Coconut battery since the early 2015 when I bought the macbook. Before this problem the battery healt status was of 87.9% ! After some checkings I've discovered that maybe the battery connector is gone, it smeels of burned but there isn't any burn sign on the connector! I get the ptt001 code with the hardware diagnostic, maybe I need to replace the battery or the connector/logic board... The magsafe still locked on the orange light. My fortune is that the macbook works fine, I need it for my jobs, but I hope that replace only the battery solve the issue :(
da B1P
