Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Questa è una buona domanda?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Guida
Difficoltà:
Facile
5 - 10 minutes
Guida
Difficoltà:
Moderato
1 hour
Guida
Difficoltà:
Moderato
9 - 15 minutes
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,002
