Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
Torx or Phillips head replacements for Tri-wing on mbp battery
The tri-wing screws that connect the battery are difficult to remove even with the correct screwdriver. Are there any other screws that I could buy, either torx or philips, to replace them? How can I look up the appropriate screw type?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
They’re not difficult to remove I repair macs as a side business and the correct tip from ifixit grips these screws without movement. You need to use the correct Y0 driver which is standard in the ifixit mako kit not a cheap three headed philips driver that comes in all the chinese battery kits.
Punteggio 0
Aggiungi la tua risposta
Nikolaos Katzakis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 92
