Salta al contenuto principale
Il Galaxy S7 Edge è la variante schermo curvo del telefono top del 2016 di Samsung, il Galaxy S7. Annunciato a febbraio 2016 e lanciato l'11 marzo. Modello SM-G935.
369 Domande Visualizza tutte
How do I flatten a removed battery?
Hi,
I’ve just finished removing my S7 edge’s battery. Due to the strong adhesive the underside of the battery comes out warped.
Since i want to reuse the battery (Which is not recommended), I have to flatten the underside so that it sits flush inside. Any ideas on how to do that?
Thank you.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi @stuig ,
There is a reason why reusing an already distorted battery is not recommended. It may become dangerous and create a fire hazard etc.
I think that you should just replace the battery as you can cause more damage and possibly more problems i.e. expenses, if you try to fix it so it fits again.
Just my $0.02 worth
da
Hey @jayeff
I understand your concern, however I believe that the battery was removed without damage. (no punctures / bending).
da
Aggiungi un commento
1 Risposta
I would not recommend reusing the battery. You can buy a new battery for around we 15 dollars. If you are adamant about reusing the battery don't use any metal tools I wouldn't try to flatten it a lot. The cells are separated by a thin sheath of i believe plastic and if it tears it will start a fire that you can't put out. If it's in your pocket it could burn you severely. If you are on a plane you could cause a serious pproblem. The smoke is toxic. I had a battery ignite right after I pulled it out of the phone. It happened when I first started working on phones. It made a smell that lasted for a week. It left a burn mark on my silicone solder mat that can take temperatures over 500 degrees. Is it really worth 20 dollars for a replacement battery and shipping. I'm sure you can afford 20 dollars
Punteggio 0
Aggiungi la tua risposta
Nvidia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 99
