Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 Resistor Question and lookup.
Hi! I have an iPhone 7 with vibration issues, I’ve done some replacing and this one resistor R2711 came off and I have lost it. Can someone either link a site where I can purchase some of them or is just bridging it with a wire enough?
Phoneboard R2711
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It is 0 Ohm resistor. Power 1/20W, Package 0201
You can find it for example on Aliexpress: https://www.aliexpress.com/item/32964976...
It cost 2$/100pcs
Or maybe you have another iPhone motherboard to swap it?
Punteggio 0
I found a place that sell the resister in ax30 second search on Google. The company name is digikey.https://www.digikey.com/products/en?keyw...
Punteggio 0
1 Commento:
If you will link the component I will give you the answer.
da
Aggiungi la tua risposta
Preston Elrod sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 673
