Salta al contenuto principale
Il DualShock 4 CUH-ZCT2 è stato annunciato nel 2016 per sostituire il controller CUH-ZCT1 rilasciato nel 2013. Questo controller è simile al modello precedente.
Ps4 controller O button not working
Hi just wondering if anyone can help me my ps4 controller O button not working yesterday i noticed when i pressed the O button nothing happens and after pressing the button 5 or 6 times it worked but now nothing everything else on the controller work's except the O button
Can anyone help me please
Thanks
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi Jamie!
I advise to open up the controller and clean it. Do not forget to clean the ribbon circuit board. And make sure it’s all seated as it should and connected.
If that won’t work, replace the ribbon circuit board, this should fix it.
If you order one, make sure it’s identical to the one which came out, there are a lot of models available and they are different!
Punteggio 3
2 Commenti:
Thank you for your reply i have opened it and cleaned it no i will order a new ribbon for it and thank you or reminding me to check and make sure i order an identical one i would of just ordered the first one i see thank you
da Condividi
Your welcome! Good luck with the repair! Yes, you need to order the one which is identical of what you got now.
da Condividi
Aggiungi la tua risposta
Jamie Edwards sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 33
Tutti i Tempi: 8,766
