Salta al contenuto principale
Pompe elettriche autoadescanti con ingranaggi elicoidali, prodotte da Marco SpA.
28 Domande Visualizza tutte
Can I reverse the direction of flow on my oil pump - RESOLVED
Can I change the direction of flow by simply reversing the positive and negative connection to the UP2 oil pump ? The direction is backwards for my application in where it needs to be mounted.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Do you know the construction of the pumps impeller?
Many are directional so while you might be able to run it backwards you lose the effectiveness of the pump!
Maybe you need to look as the piping to it, can you reverse the connections?
da
They look like bronze helical gears and piping the system another way is unfortunately not possible. It would be sloppy and cumbersome looking.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
It’s been confirmed by the manufacturer. It’s okay to reverse the wires going to the pump to Reverse the direction of flow. The discharge side will become the inlet side.
Punteggio 1
Aggiungi la tua risposta
Paul Cioletti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 283
