Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Why wont my phone turn on when I press any of the buttons?
my iphone 6s wont turn on when i press the home or lock button. i kept it on charge all night for more than 7 hours. but it still wont turn on when i press any of the buttons, however it does randomly flash my lock screen for point 2 of a second then turn off. i dont know what to do. anyone hvae any ideas?
Questa è una buona domanda?
Punteggio 1
2 Commenti:
What happens when you plug it in to a charger?
da
Do you feel vibrations when you use the mute switch?
da
Aggiungi un commento
2 Risposte
Hi! Due to the age of this phone, I would expect the battery to start degrading, you most likely need a new battery or a new lightning connector.
Punteggio 0
Have you tried a different charger? If that won't work, you may have to replace the charging port. Before you try replacing the port,try using the compressed air can for electronics and blow out the dust in the port with canned air. That worked for my 6S plus.
Punteggio 0
Aggiungi la tua risposta
Taylah05 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 61
