Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
20 Domande Visualizza tutte
Replacement screen not sticking to device
I have replaced the screen on an iPad as the original was cracked. The new screen does not stay fully attached to the device, does the adhesive need to be heated for it to attach?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Which areas are pushing up? If its the bottom left you’ll need to use B7000 liquid glue to hold that corner down and use scotch tape to keep pressure on that spot until the glue sets.
Punteggio 1
1 Commento:
It’s most sides apart from the top, I’ve reattached for now but will need to glue if doesn’t hold. I know some adhesive needs heating to activate so checking I hadn’t missed anything
da
Aggiungi la tua risposta
Michael Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 104
