Salta al contenuto principale
Un'estesa varietà di guide di riparazione per attrezzature elettroniche, a partire dagli elettrodomestici, fino all'audio della macchina e le calcolatrici.
26420 Domande Visualizza tutte
Recommendation to track down an LCD supplier for a TASCAM DR-05 please
I have a TASCAM DR-05 audio recorder that has a monochrome orange LCD whose display has partially been damaged. Only the bottom half can be read while the top half is blank. I would like to attempt to change out the LCD by finding a replacement. I need help in finding a source for a replacement LCD. I’ve included a picture of the LCD on the PC Board just in case it might help. Would you please be able to point me in the right direction? Thanks in advance for your time and help.
P.S. I am aware it is not worth the effort to repair and it would definitely be more prudent to just buy another DR-05. That’s not the point. It’s a personal challenge to see if I can fix it. This is purely for fun, therefore no need to be tempted to let me know that I should just buy another DR-05. It’s not what I want to do. Thanks.
Questa è una buona domanda?
Punteggio 0
2 Commenti
did you ever find out where to find a supplier? I am having the same problem.
da
Im in the same boat man. The device functions perfectly well other than a shattered screen. Good luck everyone!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @edd1e
Here’s the service manual.
To download the service manual, after you click on the reCAPTCHA test and clicked on the Go to Download link below the Document preview box be patient as it takes a bit of time to go from processing to Download. When it does click on Download.
In the DR-05 sm.pdf file go to p.21-22 (part #29) to view the LCD screen pcb.The LCD screen is on a board with part number E95416100A.
There are no results when searching for the pcb part number.
As for the screen itself check on the back of the screen to see if there is any identifying information and search online using that information.
You could also use the schematics (DR-05_schematics.pdf) to test and see if the LCD screen is the problem or whether the problem is on the pcb. First check that all the screen’s connections to the pcb are OK just in case that is the problem.
Hopefully a start
Punteggio 3
2 Commenti:
Awesome. Thank you, I saw this site before but was unsure if I should venture in. Glad to have you validate it for me and point me straight to the docs where I can identify the LCD. Thank you. I dropped the recorder, so I'm guessing it's the LCD, but nonetheless, I'll check the PCB as well. Thanks for the pro tip. This is awesome, thank you!
da
Did you manage? My display is also broken
da
You can find them on aliexpress apparently!
https://m.aliexpress.com/item/3281659445...
https://youtu.be/SJ5q1CZuk5I
Punteggio 0
Aggiungi la tua risposta
Eddie de la Rosa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 872
