Salta al contenuto principale
Model number: 20R1000RUS, Released in June 2019
8 Domande Visualizza tutte
Lenovo X1 Carbon boots to a 2100 error
Need Solution
I have purchased lenovo x1 carbon ( 7th generation) 1 month ago.Everything was working fine,and one day when i switched on my laptop i see this error 2100: Detection error on Storage Device(M.2).I have taken out the ssd and plugged-to another laptop it gives me same error.Now I wanted to recover my data the problem is that I am using different recovery tools but ssd is not showing in all the recovery tools.Any solution of this problem?And can any one tell me the reason of this error?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
When you get the 2100 error, it’s usually an issue with the drive itself or a drive stuck in BSY status - in other words, software is not likely to help. If it’s a BSY issue and you know what you are doing(!!!), you need to get into the drive’s diagnostic mode and refresh the controller to kick it out of the BSY mode so it can register again. DO NOT TRY THIS IF YOU DO NOT KNOW HOW; ONE CHARACTER ERROR CAN BE FATAL!
Since the drive isn’t showing in software, something is seriously wrong with the drive, and it has a physical issue or a mapping issue that requires professional assistance since end user software tools aren’t helping - you’re going to pay a lot for this :-(. Hopefully you have a backup or you can recreate the data!
If you do not have a backup, you had to learn the hard way sadly.
Punteggio 0
It's usually lose connection and in case of SSD it's baad connector. Get it replaced in repair shop and thank me later. No other solution.
Punteggio 0
Aggiungi la tua risposta
Syed Wajahat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 100
Tutti i Tempi: 2,577
