Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
No functions work unless screen is off
It's a weird issue I have here.
My touch screen, home button, power button, literally everything does not work unless the screen is off. So if the phone is powered off the power button works fine, if the screen is off the home button works fine. What do I do? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would try a hard reset, press and hold the power button and home button at the same time and hold them until the apple logo comes up. Try that and see if that will work.
Punteggio 0
4 Commenti:
Hey, update. Pretty sure it's the screen somehow shorting it out. I put it on another 6s and it now has the same symptoms.
da
Did you put the screen back on the other phone and see if it works on it?
da
I've only got that screen between the 2. But the same thing is happening on both phones when I use the same screen.
da
Then it sounds like it needs a new screen if it does the same thing on both phones.
da
Aggiungi la tua risposta
Jakob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 40
