vintage fan .the Isolation is stuck ,can it be fixed?
the Isolation is stuck,the knob is off and it keeps trying to do it and “stuttering” in it attempt .if I use it will it burn out the motor ? and can it be fixed ?
Questa è una buona domanda?
Hi @heyscripty
Check if you can manually position the oscillation control and if the oscillation gear is OK and see if this resolves the problem.
Here’s the ifixit Holmes Blizzard Fan Oscillation Gear Replacement guide that may be of some help.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 166
