Salta al contenuto principale
Successor to the PowerShot G7 X, the Mark II was released as Canon's flagship model in 2016.
20 Domande Visualizza tutte
camera says "memory card locked"
My memory card has the switch in correct position as i can view pictures on a computer and on the camera screen, however it says Memory card locked the whole time and wont let me take pictures because of this? please help - Thank you. Lollu
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi! Have you solved this problem?
da
on the sd card there is a lock switch if it is down flick it up and it should work because i have had this problem before
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If the lock switch is in the open position, it usually means the flash is in a permanent read-only state. When the lifetime of the flash is close to being used up, this is a safety feature to preserve the data as reading doesn't do much harm to the card, if any at all. They allow this as a means to move the data, at most. Be glad it acted this way, since a lot of cheap cards which do not self lock tend to fail and take out whatever is on the card. Having to buy a card on short notice is far from ideal sure but I want a chance to save what's on it.
If you want to try and see if it can be fixed, backup the card to a PC, and then format it in the camera and see. In most cases, the flash is end of life and it will fail as it's a firmware level lock.
Punteggio 3
1 Commento:
Thank you very much!
da
Hi,
There is manual lock option on Memory card used in Camera; please see the picture and try to solve the issue.
Punteggio 1
Aggiungi la tua risposta
lollu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 49
Tutti i Tempi: 4,333
