Salta al contenuto principale
Successore della PowerShot G7 X, la Mark II è stata lanciata come modello di punta di Canon nel 2016.
camera says "memory card locked"
My memory card has the switch in correct position as i can view pictures on a computer and on the camera screen, however it says Memory card locked the whole time and wont let me take pictures because of this? please help - Thank you. Lollu
Questa è una buona domanda?
Punteggio 1
2 Commenti
Hi! Have you solved this problem?
da
on the sd card there is a lock switch if it is down flick it up and it should work because i have had this problem before
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
If the lock switch is in the open position, it usually means the flash is in a permanent read-only state. When the lifetime of the flash is close to being used up, this is a safety feature to preserve the data as reading doesn't do much harm to the card, if any at all. They allow this as a means to move the data, at most. Be glad it acted this way, since a lot of cheap cards which do not self lock tend to fail and take out whatever is on the card. Having to buy a card on short notice is far from ideal sure but I want a chance to save what's on it.
If you want to try and see if it can be fixed, backup the card to a PC, and then format it in the camera and see. In most cases, the flash is end of life and it will fail as it's a firmware level lock.
Punteggio 3
1 Commento:
Thank you very much!
da
Hi,
There is manual lock option on Memory card used in Camera; please see the picture and try to solve the issue.
Immagine
Punteggio 1
Aggiungi la tua risposta
lollu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 52
Tutti i Tempi: 5,375
