Salta al contenuto principale
The Dell Inspiron 15-7567 laptop was released in 2017.
Do you sell a laptop battery?
My laptop's battery just inflated. I need to replace it. Do you sell battery for dell inspiron 15 7567?
Immagine Replace a 6600 mAh battery compatible with select Dell Inspiron 15 model laptops. 11.4 Volts (V).
Prodotto
Dell Inspiron 15 357F9 Battery
$69.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @jshdlssnts ,
Unfortunately ifixit does not have the battery you are after.
Try searching for Dell 357F9 to find suppliers of the battery. This part number should also be on the battery in your laptop if you wish to verify that it is compatible or not. It is used in a lot of Dell Inspiron 15 7000 series laptops.
Punteggio 1
2 Commenti:
@jayeff do you know where i can find one?
da
@jshdlssnts
Here's just one supplier
As I said just search as described above to get suppliers that suit you.
This is what I got when I searched.
da
Aggiungi la tua risposta
Joshua Delos Santos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 160
