Salta al contenuto principale
Touch Pad not working in windows 10.
My name is Danish . First my laptop had windows7 then I changed to window10 but as I changed my touchpad stopped working with no responses. I tried to install drivers with windows 10 but another issue came that windows 10 32 bit drivers were not available. Other devices like my external mouse of Logitech is working also wifi and Bluetooth but my touch pad is not responding. Even I tried from Device Manager to upgrade my driver but the notification that Best drivers are already installed was coming.
I would be waiting for my Answer.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @d08521362 ,
Just verifying that the OS is Win 10 32-bit, is this correct?
Does Device Manager show that the touchpad device status is This device is working properly? To view the status, right click on the touchpad entry in Device Manager > Properties > General Tab > Device status.
Did you check that the touchpad is enabled and has not been disabled? Go to Start > Settings > Devices > Touchpad > On
Is the installed touchpad driver a Dell driver or a generic Windows driver?
If it is the Dell driver did you try uninstalling it and replacing it with the generic Win 10 driver?
Here’s a link that shows how to this.
Punteggio 1
Aggiungi la tua risposta
Danish Mondal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 558
