Salta al contenuto principale
Guide di riparazione per la Ricoh Theta S, una fotocamera digitale a 360 gradi in grado di scattare foto e registrare video in HD.
When power on flashes once in blue, and twice in red, then shuts down
It fell down from one meter height…
After that, when powering on it only flashes once in blue, and twice in red, then shuts down.
What could be the problem?
Questa è una buona domanda?
Punteggio 0
1 Commento:
I have the same problem with burns
da Condividi
Aggiungi un commento
1 Risposta
Hi, ,
Falling down from a 1 metre height is not good, especially if it landed on a hard surface.
Since it is not staying powered on the only thing that you can do at the moment is to open the device and check for any obvious damage such as broken or loose connections or even components that may have been jarred loose by the fall.
Here’s the ifixit Ricoh Theta S guide that may be of some help
Punteggio 0
Aggiungi la tua risposta
david sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 805
