Salta al contenuto principale
The Dell Dimension E510/E520 is a desktop computer released in 2004.
7 Domande Visualizza tutte
Restore Dell Dimension E521
How do you restore or repair a dead Dell Dimension E521?
Questa è una buona domanda?
Punteggio 0
1 Commento
What is wrong withit?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @tear_fall12
What really happened?
cannot power on or boot up well?
IIRC this Dell series, notorious for bad bloated capacitors in the mainboard.
http://iamnutsandsoami.blogspot.com/2012...
Inspect the board and the power supply unit on that.
Punteggio 2
2 Commenti:
It's *usually* the power supply. Any ATX unit will suffice on these, but you need to watch the cable length by the hard drives. The motherboards are usually solid.
da
I appreciate your help. I will have to find some times to try it out.
Thank you very much
da
Aggiungi la tua risposta
Maikao sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 273
