Salta al contenuto principale
Modello A2115 / 2019 / processori da i5 6-core 3.0 GHz a i9 8-core 3.6 GHz. Rilasciato il 19 marzo 2019.
How do I remove JUST the front glass for replacement? iMac 27in 2019
Hello.
I recently made a small crack on the front glass of my iMac 27in 2019. I would like to just replace the front glass but all the guides I see show how to replace the entire screen and not just the glass. They also don’t show how to separate the glass from the screen once you have removed it.
Can anyone show me a guide on how to simply replace just the protective glass and where I can find the part?
Thank you.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Here’s the guide you’ll need to follow: Sostituzione Schermo Retina 5K iMac Intel 27"
You will need some tools:
  • Plastic Cards I would recommend getting two sets.
  • iMac Opening Wheel If you get the a [prodotto collegato mancante o disabilitato: IF174-005] kit the tool comes with it.
As far as the part, this gets tricky! The glass is part of the display assembly so you can’t replace it alone. Because this is such a new system getting a new part is not that easy (and expesive!) I would get this used one:
https://www.thebookyard.com/product.php?...
Immagine Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172
Prodotto
Plastic Cards
$2.99
Immagine Cutting wheel for releasing the adhesive on some iMac models.
Prodotto
iMac Opening Wheel
$7.99
Punteggio 1
Basically, you can’t. Shockingly awful design. The best you can do is re-purpose the display panel: Remove the glass from the panel using some dental floss or similar to cut through the gunk which bonds them together, then use alcohol to remove the gunk from the display. You can then buy a display driver board for ~100 Euros and make your own display cabinet.
Punteggio 0
Aggiungi la tua risposta
Guillermo Fernandez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 96
Tutti i Tempi: 6,260
