Fuse blows when door closes after replacing fuse.
My microwave went blank the other day. Replaced the fuse and everything came on, including the inside light even thought the door was closed. Able to set the clock like normal, placing it back in the wall then opening and closing the door, blows the fuse again. This microwave was serviced not too long ago and supposedly all the interlock switched were replaced. Any tips?
Questa è una buona domanda?
3 Commenti
I have the same problem. Can the fix be “do it yourself “?
da Rose Giusto
@rgiusto
What is the make and model number of the microwave oven?
It is repairable but it depends on how familiar you are at fixing electrical equipment using testing equipment e.g. digital multimeter to locate where the problem is.
da jayeff
I don’t have experience with electrical.
Will need to have a professional fix it unfortunately.
Thank you for your response :)
da Rose Giusto
