Salta al contenuto principale
Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5 Domande Visualizza tutte
touch pad replacement Asus n53
My top cover broke and I got a replacement for it but comes with no touchpad. is it possible to remove the touchpad from the original cover and install on the new cover? if so how can I do it?
Questa è una buona domanda?
Punteggio 1
2 Commenti:
Can you add pictures of the new cover and the old one, it would help to know more exactly what part is missing on the new one and needs to be moved.
Aggiungere immagini ad una domanda
da
Apologies. Unfortunately I've already fixed the device therefore I won't be able to take any pictures.
The touchpad board is actually glued to the cover I had to heat up the touchpad area on the cover (not the board) and used a metal pry tool from my IFIXIT to remove it.
Bit by bit the glue was coming off.
I was able to just stick it to the new cover and is working well
da
Aggiungi un commento
1 Risposta
Hi @xinwarrior
Based on some research into the ASUS N53 it looks like this touchpad is easily transferred after removing a few surrounding screws.
Punteggio 0
Aggiungi la tua risposta
Joao Araujo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 303
