Salta al contenuto principale
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
Why does my right bumper push my right trigger when repairing?
I’m trying to fix up a faulty right bumper and when putting in the new bumper plate it seems to push the right trigger as well whenever I seat it correctly. I’ve checked and there doesn’t appear to be anything different to the left side which doesn’t push the trigger when the bumper is pressed. Does anyone know what part may cause this and how to fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
my only guess would be that the thing it’s connected to is bent or something, I’m not 100% sure because the only Xbox controller I have ever popped is the normal one.
Punteggio 0
It is not sitting right, try depressing the trigger before you put in the bumper. I've had the same issue when I try to put back together the OG Xbox One controller
Punteggio 0
Aggiungi la tua risposta
Stewart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,212
