Why is my screen black and white when I open the screen?
I was watching Rick and Morty when all of a sudden, the screen went black. When I opened it again, it was white. PLEASE HELP ME!
Asus Laptop
Update (03/31/2020)
Well I turned it on again and it worked normally overheated
Questa è una buona domanda?
6 Commenti
Hi,
What is the model number of the laptop?
Try connecting an external monitor to the laptop and check if there is a display on it.
Even a TV can be used as an external monitor if both it and the laptop have HDMI ports and you have the appropriate cable to connect the two together.
Remember to operate the appropriate laptop function key to switch the display between the laptop screen only, the external screen only or both on together. (Fn + F8?)
da jayeff
@jayeff
It's F540M, I don't have an approatire cable. The laptop lagged sometimes, and when it had a black screen it was only the screen saver. You could hear the laptop. But now when it was the black screen, it shut down completely. Maybe overheated because it was on the whole day?
da Milo Games
@Milo Games ,
Can you hear the fan running when the laptop is on even if the screen is black?
Is the fan's exhaust vent clear, clean and unobstructed?
Do you get the Asus "splash screen" before it boots into Windows?
If not(it may be too quick) try starting the laptop and press F2 before Windows boots to go into BIOS and see if you have a display.
This is just to see if it may be a hardware problem or a Windows problem.
If you don't get a display when in BIOS either you really need to be able to connect an external monitor to prove whether it is a display panel problem or a motherboard problem
da jayeff
@jayeff I did not hear it this time, everything was clear. I dont know what a "splash screen" is.I will boot it later, may be a overheating problem
da Milo Games
@Milo Games ,
If you're not hearing the fan (or even feeling the air out of the vent) then that is maybe the cause of the problem, CPU getting too ket and shutting down to protect itself
A splash screen is when the Asus logo appears on the screen for just a few seconds when you first turn on the laptop, just before it boots into Windows.
As I said it may be too quick to see it nowadays as Windows 10 fast start speeds up the boot process.
It used to be handy to see it because at least you knew that the screen hardware was working and if there was no screen when Windows booted it most likely was a driver error
da jayeff
Mostra 1 altro commento
