Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
What is missing on this motherboard?
Hi, just picked up a cheap iPhone 6s that doesn’t turn on. I can only see 1 issue with it but i don’t know what the kissing part is or if it’s repairable. Anybody know what/ how to fix this please? There is usually a plate here but it’s gone, and I’m guessing that is why it won’t power on.
Questa è una buona domanda?
Punteggio 0
1 Commento
need a better picture of the position on the board...can assist but there are afew bended corners on this board
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The component missing is an inductor on the main power rail. Unless you removed this yourself I would say your phone has a power rail short probably VCC_MAIN or possibly a charging problem.
 Obviously someone has been trying to diagnose the problem. You will need a multimeter and some board view software to continue with getting this phone to boot.
Punteggio 2
Aggiungi la tua risposta
Ben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 44
