Salta al contenuto principale
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor uses DDR3 RAM and has 256mb of VRAM. Gpu is FX 9400m
The computer freezes every 10 minutes
After upgrading by my self memory ram up to 4 gb, all seems to go fine but now every 10 minutes I see some vertical stripes on both the sides of the screen, the mini freezes and I have to turn off the machine.
What I did wrong?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
That should be the correct memory. Can you reinstall the original memory and see if the computer behaves normally. If it does you may have fallen victim to that rarest of problems--faulty new memory. If the computer runs correctly with the old memory return the new for money back or replacement. Check the numbers on the memory sent back so you don't receive it again. Good luck.
Punteggio 2
5 Commenti:
Thank you, it is a good suggestion, I hope to find the courage to open it again, I have serious problems to reconnect the antenna cables, I hope did not break anything with my big hands, I think damaged the surface of the AirPort/Bluetooth ribbon cable connector, any relation with my problem?
da
Unlikely but you may need to replace the cable if your Airport/Bluetooth do not work.
da
Power it on and test it with the case off, and the Airport antenna dangling -- there's no reason to waste time and effort putting it back together again before you know it's working 100%.
da
I was monitoring temperatures with MagicanPaster, my mini freezes when motherboard temperature reaches 71º (159.8 F), the temperature indicator turns red and the machine crashes.
With smcfancontrol it seems that fan works (1500 rpm). May be I damaged some fan or connection?
da
You are right, it seems that one of the two ram modules was defective, just reinstalled old memory, an hour with the mac running without failures
da
Risposta più utile
Are you sure you replaced the RAM with the right specs? If you are sure you did make sure you have seated the RAM properly. You can tell when the RAM is properly seated if you feel a slight "thump" when it's inserted completely. Your mini uses PC3 8500 RAM.
Punteggio 2
2 Commenti:
Yes I have used a Kingston kit 2x2Gb (KTA-MB1066K2/4G) I heard that click when inserted and the system recognize all the 4 gb
da
Good questions +
da
Aggiungi la tua risposta
SergioDeluc sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 41
Tutti i Tempi: 1,911
