Salta al contenuto principale
Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
Water leak in straight stream out of the timing cover
My van has a straight stream of coolant squirting out between the timng cover and motor how do I fix this thanks in advance
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi,
What is the model year and engine size?
da
Model is a 2000 it has a 3.8 engine thanks
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Replace the timing cover gasket.
UPDATE 3/5/20
Here’s how to do it:
https://www.autozone.com/repairguides/Ch...
Punteggio 2
1 Commento:
I kinda knew that but how to do it I don't
da
Hi,
Check that the water pump is not leaking coolant.
Here’s a link to the service repair manual for your series vehicle.
Scroll down and click on the Cooling System link , pass the reCAPTCHA test and when the pdf file opens go to p.7-19 to find the procedure to inspect / replace the water pump for a 3.8L engine.
Punteggio 1
Aggiungi la tua risposta
Daniel Billings sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 44
Tutti i Tempi: 366
