Salta al contenuto principale
Repair guides and support for your LG TV.
1342 Domande Visualizza tutte
Why does my TV click then shut off if tilted forward or backward?
If I tilt my TV forward or backward it makes a click sound then shuts off and won't come back on unless I either tilt it again or unplug and plug it back in. This really wasn't an issue as long as it wasn't moved HOWEVER a while ago it did this but when I got it turned back on the TV will not respond to the remote or the buttons on the front of the TV. There is a good picture AND sound although it's very low but I cannot change the channel, turn volume up or down, bring up the menu, turn it on or off, or ANYTHING else. The remote sensor light on the front of the TV blinks when I press a button on the remote so I know it's trying to communicate but can't. Is it a bad capacitor on the power board? Or something else? Please help. It was given to me and it's got a great picture so I would really like find out what it is. It's an LG 50PX2DC-UD Plasma (50 inch I think).
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
@aalexx918 since it does that with movement this is not typical of any component having failed. This sounds more like loose connections or loose boards. It is time to remove the back cover and check all wiring etc. on the boards. Post some good pictures of your boards, wiring etc. That way we can see what you see.
Aggiungere immagini ad una domanda
Punteggio 0
1 Commento:
So do you think I may have two or more things happening at the same time? I mean is the fact the TV won't respond to the remote or front panel buttons have anything to do with the possible loose power etc? Or is it a separate issue? Thank you for your help btw.
da
I have this proble too, its hard to Sell this tv tobsecond hand, Lot of people talking about this ptoblem, never buy LG, buy Sony, have great CPU 8core, but lot of heatsinks , I use Sony TV in work as monitor 4k60p 4:4:4 , he ran 24/7 never restart or any issue. Its coster than LG but is TV, easy sell as old TV still work. I have LG in home and for compare LG is 80286 and SONY is core i9 serious no lag TV.
Punteggio 0
Aggiungi la tua risposta
Amy Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 252
