Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Home button repair via LCD?
Hi,
Upon changing the battery within my iPhone 7 the home button does not function at all.
Reading online, it said that the most likely issue was due to ripping the home button flex cable, therefore, I ordered a replacement home button to return the functions (apart from Touch ID).
The replacement part when fitted also did not work! Therefore, I am thinking that the issue is not with the button but with the LCD flex cable. Has anyone else had the same issue?
I think my best bet is to order a replacement LCD and test that with the original home button? Anyone else agree?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes that should fix the problem. The home button flex cable from the screen usually gets a small tear right at the bend. Sometimes it is very hard to see without magnification. A new screen will return your original home buttons function.
Punteggio 2
Aggiungi la tua risposta
Ryan Parmenter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 50
