turntable does not spin
A Technics SL-220 turntable
Questa è una buona domanda?
Hi,
Here’s the troubleshooting flowchart from the service manual for your turntable. The service manual will download automatically when you click on the link.
(click on image to enlarge for better viewing).
The manual also has a wiring diagram and a parts list
Hopefully this will help you to find out what is wrong and fix it.
There is a belt located under your record platter. That is the round aluminum piece that has the rubber mat on it. Remove the platter and check to see if the long rubber belt is still intact. If it is not, you need a new one. You should also see a brass gold colored shaft that sticks up. This is the motor shaft. When plugged in and turned on it on it should be spinning, You may have to place the arm over towards where the record would start to get it to spin. It it does not spin when turned on it is your motor and it need replaced. Chances are it is just the rubber belt.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,140
