Salta al contenuto principale
Replacing Front Glass ONLY,
How Hot does the front glass have to be to starts to separate from LCD?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
The point I was trying to get at is glass only on OLED is nearly impossible because of how fragile it is.
Punteggio 0
The pixel 2 uses an OLED panel, which are SUPER thin. Anything with an OLED panel is unfortunately very difficult to do a glass only repair on with a very high failure rate.
Punteggio 0
So how many degrees C° should I set my LCD separating machine at if it's OLED ?
Punteggio 0
But it can be done right? Try using cold instead of heat,or would that matter when dealing with fragile OLED screens?
Punteggio 0
Aggiungi la tua risposta
Sir Frank Macias sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 598
