Salta al contenuto principale
Rilasciata a novembre 2016, si caratterizza per l'aggiornamento hardware per giocare in 4K e prestazioni PSVR migliorate.
387 Domande Visualizza tutte
How compatible are ribbon cables with each other?
I ripped the ribbon cable of the DVD Drive in my PS4 Pro. It is replacable I checked but I don't know how to get a replacement part.
The original cable has this printed on it:
SUMITOMO-G [RU] AWM 2896 80C VW-1 -F-
I cannot find a ribbon cable that is the exact same. Can I instead buy ++this one for example++.
The image of my broken ribbon cable:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I would imagine you could grab any ribbon cable that had the same pinout and at least the same gauge or bigger to handle the voltage. But I wouldn’t get a random one because there may be a fit issue or maybe it doesn’t flex the way the OEM cables are meant to. Replacements are available if you know where to look. If you can’t find them on the regular websites like amazon or ebay. Check alibaba or aliexpress.
Punteggio 1
Aggiungi la tua risposta
Kristof Kocsis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 789
