Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
Ps3 Ylod, Need Help Fixing
i recently got a ylod :(
its the Fat 60gb model
the problem is not with the psu, the fan starts up fine and then there is yellow flash and then a red blinking light
It probably occurred due to a lot of dust buildup, which i removed after the fault
i have been scouring the net for possible causes and fixes but can't get anything specific
Please help!
How can i find the exact cause of the problem?
What types of fixes are possible?
And What i really want to know if there is a permanent fix possible?
Any Suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
If i fix it with this method, will it be permanent or temporary?
Punteggio 2
1 Commento:
it's not a permanent fix, nothing is. If you do the YLOD repair you also need to clean out the interior and then take steps to make sure your PS3 is in a well ventilated area, and that you regularly dust the vents etc to keep the problem from recurring...that's the best any of us can do.
da
Get a heatgun and reflow the GPU and CPU SLOWLY, leave the motherboard on a stable surface to cool, the board can't move because the solder is hot and if it does, you may be reballing it
If that doesn't work, it may be worthwile to try again
Here is the guide: Riparazione Yellow Light of Death
This is temporary, a reball would be better, but it is definitely more difficult, and if you use lead solder balls, this will not happen as easily(whatever braindead child at the EPA should of known better, yet they mandate lead-free solder, should of asked us first if leaded is better!)
Punteggio 1
4 Commenti:
da
If you clean out the gook from the heatsinks, it is temporary, but maintenance is key and will reduce the chance of doing this again
da
thanks for the info...screw EPA
i ordered the ylod repair kit...will try it
da
It is also a RoHS thing too... I would bet the EPA did that stupid move
da
The First Ps3 Cinavia Fix In The Marketplace And On The Planet! Cinavia Is A Huge Problem For A Lot Of Ps3 Owners but now there is a sloution for ps3 and blu ray owners........NO MORE ERROR MSGS........http://tinyurl.com/k9bp28p
Punteggio 0
Well I suggest you hold the ON button until it beeps 2 times but it wont work the first time try it again then your done :D hopefully it will work and depends what console you have its easier if you have the $@$* ps3 but try this.
Punteggio 0
Aggiungi la tua risposta
Imran Raza sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,034
