Salta al contenuto principale
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
Samsung Smart TV UA43KU7000K - Backlight Circles spots
Hi
I have Samsung Smart TV UA43KU7000K.
After the warranty been expired I had Backlight Circles spots as in the attached photo.
Can you please inform the solution, shall I change the led strips and which model of led strips shall I use?
I have opened the TV and the leds where in their places
Thank you
Regards
HADI RAWAL
Update (01/08/2020)
It is a wave in the paper reflector.
@oldturkey03
What do u suggest?
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi
I have open the TV and this what I found [image|1971120]
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@hadirawal no image attached to your question. Use this guide Aggiungere immagini ad una domanda to add pictures to your QUESTION.
From what you are describing it does sound like some of the diffuser caps have come off the LED’s. A lot of times you can glue them back on. Of course we will have to see what it looks like to verify this.
Punteggio 1
3 Commenti:
Please see my revised question
da
2nd picture is hard to identify with my old eyes. Is that a shadow or is it dented? If it is dented you will have to replace it.
da
@hadirawal you will have to replace that. The crease will always show up and change the distant and reflection of the backlight LED's
da
@oldturkey03
Please see the attached photos
Leds are making circles around, is this wrong?
Punteggio 0
1 Commento:
@hadirawal that is correct. I am a bit confused by what you are asking. The crease in the paper changes the distance from the LED's to the diffuser sheets. The diffuser sheets are what makes the light uniform and even, instead of showing the circles.
da
Aggiungi la tua risposta
Hadi Rawal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,162
