Salta al contenuto principale
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
74 Domande Visualizza tutte
Why is my phone restarting itself
My phone keeps restarting itself, when I switch it on, the screen reads android is starting , optimizing APP 1 OF 1, then reads starting app, vibrates once switches on for less than 5 seconds then restarts again. It continues to restarts itself until battery runs flat.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @annah44 ,
Things to try without resorting to a factory reset.
Try clearing the phone’s cache partition and check if this resolves the problem.
DO NOT select wipe data/factory reset as this will erase all your data and downloaded apps and reinstall the operating system.
Try starting the phone in safe mode and see if the stops boot looping.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to check if the problem is still there or not. When it is OK then the last downloaded app that was uninstalled was the cause of the problem.
Punteggio 2
2 Commenti:
please show me how to uninstall app
da
@surekhakane
Here's the Galaxy J5 Prime user manual. Go to p.47 to see how to uninstall apps.
da
Aggiungi la tua risposta
Annah Chiweshe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 652
