Salta al contenuto principale
La Kia Optima è un'auto di medie dimensioni prodotta da Kia Motors a partire dal 2000 e commercializzata a livello globale con vari nomi. I modelli di prima generazione (2001-2005) sono stati venduti generalmente come Optima, sebbene il nome Kia Magentis sia stato utilizzato in Europa e Canada quando le vendite in tali regioni sono iniziate nel 2002.
My door won't open
My driver's side door is shut and will not open. How do I get the door panel off?
Questa è una buona domanda?
Punteggio 3
2 Commenti
It does not open with the outside or the inside door handle? Does your lock work? Do you have power lock's?
da
our car is having the same problem. local mechanic cannot fix until he gets door panel off which he cannot do because door won't open. Locks work fine. any suggestions???? will not open from inside or outside
da
Aggiungi un commento
2 Risposte
Risposta più utile
Check on here and look for an answer by ekubec. Here is a further link that gives you more details as well as pictures. Hope this helps, good luck.
Punteggio 1
hello:
Simply order a new door latch assembly for the door with problem (mostly drivers side door) thru ebay, Amazon or Partsgeek and have them deliver to you ( about $55 delivered), take to an auto service shop and they will install that for $65. After that it will work great. Door problems are due to wear and tear and latch assemblies fail and need replacement. This is a maintenance problem, like changing water pump or any other part of the car. I don't think any other way of fixing will work.
Kumar
Punteggio 0
Aggiungi la tua risposta
chadda sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 7,592
