Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Phone not onening without charger
I can't open mobile without charger .. when plugged out charger phone switch off not opening .. again i plugged charger phone opening … automatically power off and on when plugged in charger .. phone 88% charge battery notification bar says.. what is the problem battery or charger ??? I need answer
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
So (correct me if I’m wrong), the phone stays on, only when the charger is in, right? And if you unplug the charger the phone turns off? And the phone tells you it’s at 88% no matter what?
I would replace the battery in this case. If it’s turning on with the charger only, then the charger should be fine. Don’t you have another charger to test it (just to be sure) ? But anyway, looks like the battery can’t hold any charge.
Punteggio 2
2 Commenti:
Yes you r right the problem in battery i test different charger but didn't work.. thanks you for help ..
da
Alright. My pleasure. If there is anything else, please let us know!
da
Aggiungi la tua risposta
Subham sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 63
