Salta al contenuto principale
A BTX computer introduced in 2006 using a Intel LGA775 socket processor. The 5150 is identical to the E510.
13 Domande Visualizza tutte
My drives are not being recognized.
My drives are not being recognized. I have tried making sure the drives are plugged in, I have tried using a different connector, I have tried everything. The drives use the PATA Drive interface and also has support for SATA. Not even my dvd drive is being recognized. I have also tried going into the BIOS to make sure the drives are enabled. Everything seemed fine despite this matter. Ideas?
Questa è una buona domanda?
Punteggio 0
4 Commenti
Hi @proelectronics ,
All your drives or only the secondary drives and the ODD?
Just verifying that all drives are being detected in BIOS, is this correct?
da
None of the drives are showing up. Not even my boot drive in which has windows installed.
da
Hi @proelectronics
So none of the drives are showing up in BIOS.
Can you hear (or feel) the drives spin up when you turn on the desktop?
If not check that there is +12V power supply feeding the drives
If yes check the +5V power supply to the drives
da
The drives are not spinning. Also, when i upgraded the power supply, i thouroughly made sure there is a 12 volt power supply in there. plus, after the power supply was upgraded, it was running just fine. Now, it is not doing so well.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi, @proelectronics ,
Try the paperclip test to test all the voltages being produced by the PSU.
You could also try disconnecting the power to all the drives except the primary drive and check if the desktop boots OK. It may be that a drive is faulty and dragging down the voltage
Punteggio 2
Aggiungi la tua risposta
Richard Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 111
