When I connect the charger it keeps turning on and off fast
The charger lamp turns on and off fast as if the wire is shaking and it doesn't charge
Questa è una buona domanda?
Are you able to boot into Windows normally?
If the battery is not charging, it's either a...
Bad battery
Bad charging circuit (faulty motherboard)
Bad AC adapter (You can check with an alternate adapter)
You should reach out to the manufacturer for support/warranty service, or consider returning the laptop for replacement.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 100
