My Asus memo pad me172v not started and not reset, can help me?
I push down+power, down+up+power, but not function, it is hang
Questa è una buona domanda?
Hi @petja ,
Just confirming that you did the following:
Press and hold the Volume Down key
Wait a couple of seconds and then while still holding the Volume Down key, press and hold the Power key so that both keys are being held operated.
Keep holding both keys until the Recovery menu appears on the screen, then release the keys and use the Volume keys to navigate through the menu options and the Power key to enter.
Thanky
But no function
it doesn't work. when I press and hold down key and I press and hold and power button it tends to turn on but it lasts a long time and stays that way. when I do the same with the volume up + power button. while holding down both buttons, down + up and pressing the power button appears on the screen the cursor sign? and no USB cable cone
Thanky but I not see any menu operation, I see only no cable connection or ready to download and no things to do
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 291
