Salta al contenuto principale
The iRULU AX106 is a 10.1" Android 4.0 Dual Core Tablet PC with 1GB RAM, 8GB ROM, Dual Camera, and Wi-Fi support.
What does red triangle when turn on mean
When I try to turn on my irulu I get a battery symbol with a red triangle in it. What does this mean? And how do I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @sissystablet ,
It usually means that the battery has fully discharged.
Try leaving the charger connected for a while, even 1-1.5 hours and check if the battery is kick started into charging again,
If it does start to charge allow it to fully charge before turning on the tablet.
If it doesn’t start to charge either the battery has been depleted beyond recovery and needs to be replaced or there is a problem with the charging circuit in the tablet.
Punteggio 1
Aggiungi la tua risposta
Susan Bosman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 516
