Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Auto-Brightness setting present but not working. Screen replaced
After replacing the display assembly on my iPhone 6S the auto brightness feature has stopped functioning. The replacement display was a complete OEM genuine assembly taken off of another iPhone so the sensors are genuine.
I still have the option to turn auto brightness on and off in settings (iOS 13.2.3) but the brightness doesn’t actually change depending on the light level in the room.
I have reset the phone in settings, should I try resetting it from iTunes instead?
Thank you,
Oliver
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Transfer the front camera assembly (FCAM) from the old screen to the replacement screen. The replacement screen probably has a faulty pre-installed FCAM assembly which has an ambient light sensor on it (ALS)
Punteggio 1
1 Commento:
Thank you for your suggestion @benjamen50! I'll give this a go. It's funny that the Auto Brightness option is still present - normally it disappears so maybe the ALS is at fault.
Thank you
da
Aggiungi la tua risposta
Oliver sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 42
