Salta al contenuto principale
WIll replacing the data cable fix my problem?
I have a 15inch Macbook Pro, model A1211.
I plan on buying a new display data cable for it. I want to make sure it will fix my problem.
my macbook pro's screen is in good condition, no cracks or scratches, but the colors are distorted. if i plug in an external monitor, it works fine.
I just want to confirm the display data cable is the correct part I need.
MacBook Pro 15" (Models A1150/A1211) Display Data Cable
Immagine MacBook Pro 15" (Models A1150/A1211) Display Data Cable
Prodotto
$19.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Looks like you did a solid job of trouble shooting, but I can't be sure this will fix your problem. The data cable is your most likely culprit, and it should solve the issue, but sometimes the only way to find out is to install a known working part and turn it on.
Good luck sir!
Punteggio 2
2 Commenti:
A good answer. +
da
+ solid answer could be the cable or screen
da
Aggiungi la tua risposta
matthew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,000
