Salta al contenuto principale
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
LCD SCREEN stopped suddenly after hit a splash of sea water
The camera hit a splash of sea water and then appeared on the screen a full blue color and then all the information went gradually then no any thing on lcd screen …. note that the camera is working when I shoot from viewfinder and i replacement LCD to new lcd screen and not solved ..!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
IBRAHIM V.I.P  sounds like water damage to the motherboard since you already replaced the LCD. Use these guides Canon EOS Rebel T3i / 600D to work on your camera. Remove the motherboard and clean everything with 90%+ isopropyl alcohol and a soft brush. Check the board for obviously damaged components etc. If nothing else you can post some images of your motherboard with your Question. That way we can see what you see. Aggiungere immagini ad una domanda
Punteggio 1
Aggiungi la tua risposta
IBRAHIM V.I.P sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 240
