Can I fix the screen
Is there a way to fix screen on curved tv
Questa è una buona domanda?
Hi,
If the screen is cracked then it cannot be repaired, it has to be replaced.
You could try finding the screen’s part number, which is on the back of the screen itself and search online using the part number to check if any are available.
If you do happen to find one, then you’ll most probably find that it can cost nearly as much as a new TV.
I suggest that you advertise your TV as (insert make and model number of TV) faulty screen - good for parts to try and recoup some of the cost towards a new TV.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 89
