Salta al contenuto principale
The Ford Super Duty (also called the F-Series Super Duty) is a series of trucks produced by Ford Motor Company, an American automaker.
31 Domande Visualizza tutte
Turn key makes hmmm sound, wont crank or turn over, dash lights on.
After cylinder 2 misfire code I changed coil packs and spark plugs twice in case bad part. Now makes a hmmm sound but won’t crank or turn over. Dash lights are on. F250 super duty 5.4 v8.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Here is a list of possible causes:
https://dannysengineportal.com/starter-p...
I would start with confirming the battery is good and well connected. Clean the contacts, etc. Mostly focus on the starter, since you should hear it trying to turn the engine over whether the spark plugs are setup correctly or not.
Punteggio 0
Aggiungi la tua risposta
Ken Wieteha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 39
