Salta al contenuto principale
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Screen brightness resets after restart
I have a Galaxy Tab A 8.0 SM-T387 that has a brightness issue. After I start it up, the brightness is all the way down on the dimmest setting. I turn it up and it stays up, thankfully, but when I start it up again, the brightness is all the way back down again. Is there a way for me to force it to keep the brightness where I put it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
After you have adjusted the brightness setting, re-start the tablet in safe mode and check if the setting is still correct.
If it is then a downloaded app may be the cause of the problem.
The trick is to find out which one is the culprit.
Punteggio 2
Aggiungi la tua risposta
godingservices sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,551
