Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone stuck in recovery mode
My phone started randomly shutting off and then on again. Every time it would turn on, it would be on for a minute or even less, turn off again and then start turning on again on its own. I tried fixing it by getting it into recovery mode - that didn’t work even though I tried doing it multiple times. At some point, my phone just got stuck in recovery mode, and now it won’t turn on at all.
I also tried connecting it to iTunes and updating iOS while in recovery mode, but every time I would get some sort of error, usually error 75.
I have no idea what else to do, and I would like to avoid putting it into DFU mode. Any help would be greatly appreciated. Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If a new battery and charge port doesn’t improve the situation, then your next ‘most likely’ fault would be damage to the tristar usb recognition chip which can cause these symptoms. Changing tristar is not a DIY job, but can readily be done by any competent microsolderer. If not tristar, then it can be failure or corruption of the flash memory chip.
Punteggio 3
Aggiungi la tua risposta
anastasija sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,221
