Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
oh no please help my iPhone 5s volume button does not work
Hi i have a big problem or so i think. my IPhone 5s volume button does not work it clicks fine and everything seems fine with the cabel any ideas how i can fix this? btw i just changed the screen.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try turning on the Assistive Touch.
While this won’t actually fix your problem it gives a temporary solution that allows you to adjust the volume of your iPhone. You simply go to
Settings>General>Accessibility and turn on Assistive Touch.
If you try to tap the volume buttons they may work after a while. What I believe you may have to do is re-seat the cables and try putting the phone back together. It is possible one of the cables may have been damaged during replacement or it could have been a defective part if everything went smooth. Not uncommon with some places but I wouldn’t rule out damage either.
Punteggio 2
1 Commento:
Hi thanks i will try does stuff but i did not reaplace the volume button. i take a look again if i can find anything.
da
Aggiungi la tua risposta
Bertil II sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 101
