Laptop power up but have black screen
I plug in the pc but keep blank screen
Questa è una buona domanda?
https://okadtech.com/learn-how-to-fix-ac...
Go and solve your problem and thanks me later
The "black screen of death" is usually very easy to repair on a laptop. The screen might remain black when there is a corrupted graphics driver or a problem with the LCD display back light. To test the display, attach an external monitor and restart the computer. This test is helpful if the display is black but you can hear that the computer is operating.
If the external monitor works, the trouble is with the display or its cables. You should also confirm that your memory is properly installed.
You can also try to turn your computer by pressing and holding down the start button. Next, unplug the computer and remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Getting no results usually indicates a bad motherboard.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 10,334
1 Commento
My acer notebook is showing a black screen but the blue light on the side is on
da Rochele Thompson
